Old 06-16-2008, 08:47 AM
dblvenom dblvenom is offline
Carmine,
When I manually enagae the fans from my dash toggle switch, the temperature drops down quickly. In 100+ degree heat in traffic the car would not exceed 90C with the fan on. I think a faulty thermostat would cause overheating since the water/coolant would not be able to flow. Really appreciate the feedback.. For the group, I did test the wires going to the switch by removing the two leads and having them touch. The fans kicked on leading me to believe that I have power at the switch. This is my second switch. I am wondering if maybe my temp gauge may not be accurate (out of calibration).Planning to borrow an infared temperature sensing tool to check the temperature at the sending unit. Thoughts?
