Old 06-16-2008, 10:38 AM
CobraDan's Avatar
CobraDan CobraDan is offline
Kevin,
Put your snaps where you want on the body and then take a piece of clear plastic and make a pattern of the tonneau cover needed to cover your cockpit. Don't make one with the zipper down the middle as this will be where the rain will come in at. The pattern should be taken to a place that can make your tonneau cover but at this time with out the snaps inserted. When the cover is finnished take your car to the shop and then starting on one side they will put a snap and attach it to your installed snaps on the car one at a time. By doing it this way and pulling it taught it should fit like a drum when completed and no water will collect on it, as the body lines of a cobra are higher in the middle to start with.
Dan Wulff
