Old 06-18-2008, 11:12 AM
jdean's Avatar
jdean jdean is offline
Ditto on the Proform 950 HP.....runs great out of the box, has lots of extras only found in carbs costing twice as much. Double pumper, Billet base plate and metering blocks, 4 corner idle. I know it works well because I tested it with the Innovative Wide Band set up. Holds correct AFR from off-idle through WOT.
6th generation Texan....
