Old 06-18-2008, 02:47 PM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
I have 2x4 600 with vacuum secondaries.
I find them little problem to set up and I haven't touch them since.
The factory linkage set up is very quick ratio and is tricky to throttle steer with. More like pressure on pressure off.
A single four gives you more pedal movement to throttle steer.
That being said I like the throttle response of the 2x4 very much.
