Old 06-20-2008, 01:35 PM
Rick Parker's Avatar
Take the carb off and after emtying the fuel, back off the idle speed screw (not idle mixture) and hold the carb up to a strong light, looking throught the top of the carb. You want to verify the throttle plates are closing properly and very little (if any) light shines around the perimeter of the throttle plates. If necessary adjust plates within the shaft. If any screws are removed use red Locktite when replacing them. Then reinstall the carb and sycronize as well as possible. If necessary you can use some very small open end wrenches (like ignition wrenches) on the flats of each end of the throttle shaft. You do not want to use anything that will give you a lot of leverage. Twist gently, opening the one with lesser flow to match the other, do this gently. Recheck with flow meter until you are satisfied, then resyncronize.
This assumes ther is no mechanical differnces betwen cylinders such as bad valve, worn cylinder or major compression difference.
Rick
