Thread: Temperature
Old 06-20-2008, 06:57 PM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Least expensive solution providing everything else is working as advertised, Water Wetter with distilled water and a minimum amount of anti-freeze. Add a shrouded puller fan and you should be good to go.
Not as elegent but can help: Put about a 1" foam block under the back of the hood to increase air flow around the engine.
DonC
