Thread: world class t5
Old 06-20-2008, 08:03 PM
63mercury's Avatar
63mercury 63mercury is offline
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
I have a healthy 460 in my Merc and use Castrol full synthetic since changing the break in oil. I use Castrol in all my engines and motors. Also I use Baldwin filters on the Merc and the Mfg'r filter on stockers.I read some tests on Fram and their junk. just my 0.02 worth on that subject.
The T-5 WC trans has what looks like a bearing cover on the opening just under the input shaft, it actually has a number stamped on it, if it looks like a soft plug than it's the STD version.
you can also download the service manual for that trans and it has good diagrams, I also have it on cd so I could froward it to you. Pm me if you'd like it. Carl
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
