Thread: Wiring Diagram
Old 06-22-2008, 01:59 AM
sideshow sideshow is offline
doing the column is a pain in the butt even if i have dagrams i dont use them
i get a mulitmeter and just test all the wires by switching switches and stuff
check yr engineer but last cobra i did had to have the pass lights switch working
which means when lights are off u have to be able to pull back on the lever and hi beam should turn on
this is a pain to set up cause means u have to wire up headlights exactly like factory laser then
headlights can be positive or negative triggered
i try to simplify it and always use neg trigger but then u need to use extra relays and diodes to get the pass to work
this is the most time consuming part of wiring them up the steering column
the ignition swithc should be easy
sometimes on back of switch the wires are labelled check on the black plastic where wires solder into ignition switch right behind key
my website
www.sideshowsperformancewiring.com.au
