Old 06-23-2008, 03:08 PM
Default I think that you can go with only 3/8" max
Proibe With most cobras and stack setups, 3/8- 1/2" is max. You may have an air problem with flow and the stacks being too close to the hood. What you really need to do is get 2 small bildge fans from the boating world and install them on each side of the engine compartment and have them suck out the hot air through the side air vents. Just a thought. Rick L. The fans and relays with switches are about $90.00 if you shop hard. get the 4" ones. They flow 280 cfm per fan, that will move the air. This is the same ones Nascar uses. They are water proof and heat proof.
