Thread: boiling fuel
  #25 (permalink)
Old 06-23-2008, 03:59 PM
MrMagoo's Avatar
MrMagoo MrMagoo is offline
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
If heat is causing your fuel pressure to rise to 8-9, then that could be a huge part of your problem, since Holley's are very particular about excess fuel pressure above 6.5. Before you get a regulator, do all of the cooling suggestions first, and see if you can prevent that from happening. That way, you will know if the cooling you are doing is effective.
If I can see you, I'm too close
