Thread: L76 tune
Old 06-24-2008, 05:13 AM
Doubledip's Avatar
Doubledip Doubledip is offline
Send a message via ICQ to Doubledip
as sideshow said you really need to stick a scanner on it once you get it back and started so you can see the rest of the codes that are on it..
there will be a few "lost coms with" errors for all the other devices that you ECU cant talk to like ABS and BCM
there will be a crank relearn code if the PCM is brand new
possibly a few fuel level sender errors
generator light, starter relay circuit maybe
those are just a few that will more than likely pop up.
www.ultimateconversionwiring.com.au
_
