Old 06-24-2008, 07:53 PM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Street:
It's a good idea to have your oil temp close to the 200 range to outgas contaminants. Try running an oil cooler thermostat if you're concerned that the temp is too low. There are several available that take a minimum of plumbing modifications. You should be able to find them at either Jeg's or Summit just for starters.
DonC
