Old 06-25-2008, 02:34 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Ed,
The bushing "I" need is for the upper, the one that go on the housing.
To fit the lower the total distance from steel flange to steel flange , on the housing is;
3.03. So I am guessing I can draw up tight the lower brackets to fit the listed bushing you are showing. The frame brackets are duplicating the rear end brackets.
Sure seems like the 2.544 you've got is a little loose! IF you are measuring to the outside of the rubber on both ends that is?
DV
