Old 06-26-2008, 04:19 PM
Keithc8 Keithc8 is offline
Default KC 408 Cobra/Superformance package for 57,900.00 New
Keith Craft Performance engines has teamed up with Racing Legends Motorsports to bring you the best value in a new Superformance. You can no go wrong with these two nameswhen it comes to your Cobra.
Cars will include twin stripes, glove box, stainless steel quick jacks, leather wrapped stering wheel, stainless steel expansion tank, ceramic coated headers and side pipes, soft top with side windows and tonneau cover. Nice equiped cars, not sripped down.
At the heart of this package will be our new 408 Cobra package with our new Keith Craft Signature heads. This engine makes 525HP and 535 ft/lbs of torque with 9.8 to 1 compression and a small hydraulic roller camshaft. The secret is in the new high velocity 17 degree heads that flow 300 cfms through a 2.02 valve at .600 lift. Low rpm torque with HP to spare. Fully blue printed CNC block with Eagle cast steel 4.00 stroke crank, Eagle 4340 H-beam rods, Probe pistons, moly rings, Comp Cams KC custom hydraulic roller camshaft, Ford racing hydraulic lifters and double roller timing set, Moroso front sump oil pan, Melling HV oil pump, Professional Products damper, Comp Cams pushrods, Scorpion roller rockers, Edelbrock Performer RPM intake and water pump with Keith Craft signature valve covers[other options available], Quick fuel carburetion, MSD iginition and KC wires, March pulleys and brackets with stock alternator. Engine is dyno tested and tuned as wellas being checked for oil and water leaks before installation. Engine will come with a 2 year 24,000 mile warranty on all internal lubricated parts.
Keith Craft will also be doing the installation on the cars and it will be done with top notch parts as well. New Ford Racing bell housing, Ram or McCloed steel flywheel, clutch and pressure plate, hydraulic throw out bearing, custom drive shaft, Tremec world class T-5 transmission, MSD 6Al box and coil, ride heights set and 4 wheel alignment, all fluids installed, road tested and tuned by Keith Craft Performance.
We will offer the engines with several valve cover and air cleaner combinations. Our standard set up will be our polished valve covers and polished ovaal air cleaner. We are also going to offer our black knight package at a 200.00 up-grade witch includes black powder coated valve covers, air cleaner, brackets and pulleys. This along with the black block and oil pan makes for one great looking engine.
You get this complete running and assembled Superformance Cobra Mark 3 with this great engine and install for only 57,900.00 brand new the color you want. Cars are equiped with 15 inch wheels and tires and can be up-graded to 17 inch wheels and tires for 2000.00 extrra. We have three in stock right now ready to build for you. We can also do any up-grades that you may want to the car or engine and you will still have a great value. I do not believe their is anyone out there that can offer you this package with this kind of engine and install for what we are doing here. With our great buying power and low overhead we are able to do this for you. With shipping on most cars in the 1000.00 to 2000.00 range we can ship you a car and still beat most any deal out there.
We have the following colors available right now: Black with Diamond Black stripes, Silver with Black stipes, and Dark Silver with Silver stripes. We will also order you the car you want and honor this special price.
Feel free to call Keith Craft at 870-246-7460 or 870-403-1886 or e-mail at keithc@iocc.com.
Keith C
