Thread: Really strange!
Old 06-28-2008, 11:54 AM
ron427 ron427 is offline
Dan,
If by any chance you are using the 60's style Ford starter relay with wires on both of the small post, that can cause this problem. The "second" wire which was brown was a 12volt ignition coil feed wire for 12 volts in the start position only. I have seen the relay fail to open this circuit when the ignition returns from the start position to run. Though not likely you problem, you can check this by removing the wire to see if the engine shuts off. Good luck---Ron
