Old 07-02-2008, 04:12 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Excaliber View Post
While the SOHC is the top dog the 427 High Riser heads of 1964 were a close second. Those heads were outlawed by NASCAR in 1965 and the result was the medium riser heads which became quite popular as an alternative. High Riser heads COULD compete with the Hemi. Even today a well worked set of original High Riser heads are hard to beat by ANY after market or modern 427 heads.
Dove, and I believe Blue Thunder sell "modified" Hi-Riser heads, with raised floors in the intake ports which are better than the original design I believe. However, I believe the Dove tunnel ports will still flow more than the modified Hi-Risers, but maybe not by much. The problem with the Hi-Risers and Tunnel-Ports are intake selection.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
