Old 07-02-2008, 07:53 PM
Roush #1's Avatar
Roush #1 Roush #1 is offline
Cobra Make, Engine: Lone Star Classics / Roush 427 SR
Mike,
I have heard of several others who have experienced the same problem...
clutch chatter in first gear only after a couple of thousand miles.
Several have narrowed the problem down to clutch adjustment and improper slave cylinder mounts, ie. the slave cylinder mounted to the frame and the engine and transmission moving a bit from initial torque causing the clutch to slip or chatter a bit when the engine moves on initial take off in first or any other gear. Slave cylinders work best when mounted to the engine or transmission.
The first thing I would check would be clutch adjustment and slave cylinder mounting location.
Just my $.02 worth.
Hope this helps.
Jody
PS....just curious why you replaced the slave cylinder - the same folks who have the cylinder mounted on the frame experience frequent slave cylinder failures due to tension placed on the rod on the moving end of the cylinder when the engine torques over.
Roush #1
Lone Star Classics
Roush Edition #01
Roush 427 SR #444
