Old 07-03-2008, 08:57 AM
NorCal Cobra NorCal Cobra is offline
Cobra Make, Engine: Backdraft 427 Stroker, Sterling Gray/Silver
Thanks for all your suggestions. My slave cylinder heim joint is attached and secured by an "L" bracket attached to the frame. I think I'll try to adjust it before an entire tear down.
Can the problem really be a contaminated disc? I would think the clutch would slip before any chatter would occur. Also, wouldn't chatter occur in every gear if the disc was contaminated or the flywheel was warped?
If I feather the engine and clutch just right, I can virtually eliminate any chatter (except on an incline).
The driveline appears to be fine and I am not having any rear main leaks. I think I can rule out anything from the drive shaft back.
The fact of the matter is that something is seriously wrong and baring a simple slave adjustment, a complete breakdown is iminent. Unfortunately, I lack the free time needed to drop the transmission and make any repairs. I will try to find a knolwedgable and honest mechanic here in Northern CA.
I think the easiest way to simplify what is happening is to say that the problem occurs when the clutch disc is releasing from contact with the flywheel. I believe it it one of three things would cause this:
1. Slave cylinder
2. Clutch disc or flywheel
3. Missing or out of round Pilot Bushing
Thanks everyone,
Mike
