Old 07-04-2008, 01:18 PM
scootter's Avatar
scootter scootter is offline
Cobra Make, Engine: SPF #1436 514
Make sure you didn't shear the pin on the distributor drive gear. I broke mine twice. The second time i could hardly tell until I took it apart. Get the #1 piston top dead center and see if the rotor is where it should be. First see if the button on the inside of the distributor where the coil wire hooks burned up!
Scott
