Old 07-04-2008, 02:47 PM
ERA Chas ERA Chas is offline
No No!
Don't drop the rear. Much simpler. ERA has a brake access panel in the bulkhead behind the tunnel, between the seats. Raise the carpeting, and unscrew the panel. You will then be able to remove the clip which retains each pad, slide them out and slide in the new pads. You even have room to push the pistons in if they protrude into the new pads.
You can remove the seats to make working more comfortable but not vital to do so.
Chas.
