Old 07-04-2008, 10:41 PM
lovehamr's Avatar
lovehamr lovehamr is offline
Stolen Avitar
Originally Posted by onefastmustang View Post
I am wondering if it is the 6AL itself that has faltered. Is there an easy way to test that???
The simple way is to disconnect the coil wire from the dist. and lay it where the contact is an inch or so from a ground (intake/valve cover/block etc. Not near fuel though!) then use a remote starter switch or a helper to turn the engine over. If the MSD is working and you are sure the dist. is good then you'll have a LARGE series of sparks from the coil wire. Before you do that, make sure that you are clear of the wire and arc path because you do NOT want to get hit by that puppy! Yes I do know that.
Steve
