Do you have black soot on your throttle blades or in your intake
If you do, then that is reversion. Reversion causes a loss in power because the intake pulses are backing up into the carb when the valve slams shut. These anti reversion (shear plates) can cure that and add hp. I am going to try them.
http://www.magnafuel.com/products/ac...ates/index.htm
http://www.prosystemsracing.com/cata...92/5430863.htm
http://www.prccarbs.com/PRCspacers.html
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
