Thread: Bolt on's
Old 10-03-2001, 06:30 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
When you do put the AC in it, I'd like to know how you did it, and what components you used. Contemplating the same mod myself.
HP wise, I'd use a slightly milder cam and a stroker kit (393) to up the bottom end and mid range torque. The 393 over the 351 is worth nearly 50 ft/lb TQ @ 2000 RPM.
Set the rev limiter at 6000, do routine oil and plug changes, and the engine should go about 120 - 130k miles before rebuild time.
These Fords just seem to run forever it you take care of them.
