Thread: Side Pipes
Old 07-08-2008, 11:21 AM
scootter's Avatar
scootter scootter is offline
Cobra Make, Engine: SPF #1436 514
Ed is right. There should be a gasket. Once you put the new gaskets in, you should check once in a while to make sure the bolts are tight. It can be a bit of a challenge, but I have done mine a couple of times by myself. Only use the stainless steel bolts, nuts and washers.
Scott
