Old 07-09-2008, 07:23 AM
patrickt patrickt is offline
Originally Posted by jimw427 View Post
It would be nice if you had enough shaft to get a pin through to make sure it never slides odd again even if you loose the set screw.
Yeah, I'm going to fasten something on the outside of the spline that will let me put a little pin through it. Betting it all on that set-screw, even with Loctite on it, isn't all that reassuring. But, now that I know what it is, I could probably put the darn thing back on by just propping a shoe under the clutch pedal to keep it in the right position and then reaching in under the car from the driver's side (once the pipes cool down) and slide the outside of the spline back on just by feel.
