Old 07-09-2008, 08:21 AM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
Default roll bar mounted fire suppression switch bracket?
I have a Halon fire suppression system I'm putting in my ERA 289FIA. In looking for a centrally located position for the pull cable, I thought that, rather than mount the cable in the dash I might install it on a custom bracket that is mounted on the forward brace down tube of my roll bar. This would put it within easy reach and I won't have to drill into my dash for a mounting hole.
Does anyone know of an existing product that I could use for this? Seems like a common racing need. It'd be a bracket similar to attached photo only with a 1.5" id to mount to the roll bar, and instead of a bolt through it would have a flat plane with a 0.6" id hole in it for mounting a switch.
Anyone know of something like this?
Dangerous Doug
"You're kidding, right?"
