Thread: Cobra engines
  #21 (permalink)
Old 07-10-2008, 08:43 PM
Slick61's Avatar
Slick61 Slick61 is offline
Cobra Make, Engine: BDR #89, KCR aluminum 427 windsor
meh... here's MY 2 cents... incorporate all the options & get an aluminum 427 Windsor stroker! Awesome power, very light weight, room to work on it, & good air circulation in the engine compartment. If you're putting it in a Backdraft, heat should not be much of an issue, as the body & cockpit are glassed together & seals very well. I notice more heat wafting up from the sidepipes at stoplights than I do in the footwells. With the right cam & exhaust, it'll sound as nasty as a big block, but weigh in at, or less than a small block. Every engine will sound somewhat different, depending on how it's set up. No matter what setup you go with, you'll probably always want to tinker with it.
R. Smith
Santa Clarita, CA
BDR #89- KCR aluminum 427 windsor, TKO-600
