Old 07-11-2008, 05:07 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Cpt. Ed,
Just a little update, doors have been matched and now removed, windshield removed, hood removed. Body comes back off today an put on the jig. Frame to be cleaned up and finished with the front support bar in place. Steering column and bracket has been aligned allowing final bracket mounting to begin. Engine frame mounts to be installed loose, Dash has been fitted and removed for final cut outs. Dash cover to be here Monday, will start the wiring again.
"MY" bushing has been in the freezer for three days and will be installed today for the upper control arm which should be put in today and hooked up. Anybody seen a couple of lower rear arms any where?
S L O W process at times but still progress! Body looking good.
Georges Willy's goes to the upholstery shop Monday. Your Cobra will then go into the booth!-Still waiting for the convertible top, "they ARE" ready to start making tops, still need the originial top for a pattern ??????????????????
Anybody have a tubeing bender with 6" radius die that they want to sell? Not a harbor freight type machine but a professional one?
DV
