Old 07-12-2008, 07:46 PM
C0braed C0braed is offline
Cobra Make, Engine: Classic Glass 302 Windsor
ARP have an external engine bolt kit which is resonably priced and covers all the required bolts to assembe the engine. These are available in stainless steel or moly, hex head or 12 point. As for gasket glue I prefer pocktite gasket eliminator. A hint for the front cover if you are putting a new one on prior to doing this coat the inside of the water passage with Blue max (ultra blue) silicone as a barrier against corrosion.
