Old 07-13-2008, 01:06 PM
patrickt patrickt is offline
Originally Posted by STEVE-O View Post
Is there a radiator drain valve? Do you use a mix of water/antifreeze in the radiator, plain water or water with water cooling additive i.e 'water wetter' ?
If you have a drain valve it will be at the bottom corner of your radiator. You should use a 50/50 mix of water and AF and a lot of also use Water Wetter. Do a quick search on "burping" your system as air bubbles can be a problem.
