Old 07-14-2008, 05:23 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
I run the car on the road and on the track. My first option was to go for TKO600 and run a 3.31. Then I found that quicktime where making a bellhousing to take the TUET 1806 t56 viper box. With a .50 6th and 3.54 gears I can run 70mph at 1600rpm and have the 3.54 diff for mind blowing accelaration in the lower gears or should I just stick to the TKO 600 also thinking of running an aluminium flywheel and a McCleod twin plate clutch
