Thread: ignition grief
  #30 (permalink)
Old 07-15-2008, 05:15 PM
Cobrabill's Avatar
Cobrabill Cobrabill is offline
Cobra Make, Engine: Superformance 427 Side-Oiler
Originally Posted by lovehamr View Post
Um, when did I say that? I said that "dwell" wasn't affected. You do know that there is a difference, right? Does that make the above statement 100% catagorically goofy? Or were you referring to my saying that it would take a long time for rubbing block wear to make an appreciable difference in timing? In which case the above statement would merely be lacking in accuracy and understanding. Man, this is like watching a liberal foist words into other people's mouths. I didn't say that I didn't have any point bounce, what I said was that I had no problems. And I believe that this may illustrate what everyone’s problem seems to be with this line of thought; you see, my point is NOT that points are a more precise or better way to trigger the MSD box. My point is that points are a reliable and still viable way in which to do this because most of us would never feel the difference anyway. Of course I know that your sensitive booty would pick up on those points in your distributor right away as you put on that second coat of wax!
By the by old boy; the next time you feel like showing of that big brain you may want to use spell check.
Steve
O.K.,Steve-here's ignition 101 for you:
If points bounce/flucuate-dwell changes.
If the "block"postion changes-your dwell changes
If dwell changes-your timing changes
For performance minded people this is not a good thing
This is not a debate-able point-it is proven fact.
If you want the most from your engine,points are not reliable & proven.They are antiquated garbage that belongs in a museum sans 100 point show cars& the like .(Redundant-i know).
Who is this "everyone"?
And please shove your"sensitive booty" comment up your a$$.
The rest of the world can have their opinion about the United States just as soon as WE give it to them.
