Thread: ignition grief
  #31 (permalink)
Old 07-15-2008, 06:55 PM
Scufty Scufty is offline
Cobra Make, Engine: Butler Racing/427 side oiler
Default Cobrabill
Originally Posted by lovehamr View Post
Um, when did I say that? I said that "dwell" wasn't affected. You do know that there is a difference, right? Does that make the above statement 100% catagorically goofy? Or were you referring to my saying that it would take a long time for rubbing block wear to make an appreciable difference in timing? In which case the above statement would merely be lacking in accuracy and understanding. Man, this is like watching a liberal foist words into other people's mouths. I didn't say that I didn't have any point bounce, what I said was that I had no problems. And I believe that this may illustrate what everyone’s problem seems to be with this line of thought; you see, my point is NOT that points are a more precise or better way to trigger the MSD box. My point is that points are a reliable and still viable way in which to do this because most of us would never feel the difference anyway. Of course I know that your sensitive booty would pick up on those points in your distributor right away as you put on that second coat of wax!
First of all Cobrabill this is the post that I was referring to and I dont think thats you correct? so maybe zip it regarding me if you dont mind!
And this was my original post ..if you want to get into a pissing match do it elsewhere please and thanks!
By the by old boy; the next time you feel like showing of that big brain you may want to use spell check.
Steve
First of all Cobrabill, this is the post that I was referring to and I don't think thats you correct?
This was originally my post regarding my ignition problem and seems to have been hijacked. If you want to get into a pissing match go elsewhere ...I was simply making a joke that 1 guy is telling another to use spell check and in the same sentence spells something wrong!
HAHAHAHAHA
Nough said!
