Old 07-16-2008, 10:42 AM
RedCSX1's Avatar
RedCSX1 RedCSX1 is offline
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Default You guys are confused....
Most 428 FE motors came with hyd lifters. You can have a Hyd lifter go bad and the cam will still be in good shape. YES, you can remove the lifters without removing the intake. Do not use a magnet, use as some one mentioned a tool designed to grab the lifter where the push rod sits. Replace the bad lifter then reinstall the rocker assembly. Been there, done that, and it worked fine.
Morgan LeBlanc
Fresno CA
