Old 07-16-2008, 10:05 AM
undy's Avatar
undy undy is offline
Originally Posted by FWB View Post
how do you run a feakin rocker down to zero lash on a hydraulic motor with
a rocker shaft?
that would be a good trick. number 1 lifter can be changed thru the oil fill
tube hole in the manifold. remove the tube or plug and use a lifter puller.
If it's adjustable rockers, OEM or otherwise, you run the lifter preload down till it bottoms out and starts compressing the valve. I thought EVERYBODY knew that.. sheesh..
Too many toys?? never!
