Old 07-16-2008, 11:13 AM
Tony Ripepi's Avatar
Tony Ripepi Tony Ripepi is offline
Cobra Make, Engine: TBD
Hello Automan,
The 427 likes to run better when it hot 190 degrees is where it is happy, above that and it is way too hot.
As mentioned above look to what direction your fans are blowing but, I would recommend a pusher and puller fan combination. I looked in your gallery but, could not see what pusher fans you are using. If you are using the two small Aluminum units they are more decoration not real cooling functionality. I would look to mount a high efficiency puller behind the radiator i.e. Spal etc. that would pull the air through and give you the cooling needed when you are running slow in traffic.
Hope that helps,
TR
