Old 07-16-2008, 12:36 PM
patrickt patrickt is offline
Originally Posted by fkemmerer View Post
Thanks Patrick, I will check the set screw and locktite it!
One other thing that you might consider doing since it looks like you are going with the ERA outboard rear with the handbrake. The brass looking cable brace that sits on the frame really gets in the way of servicing the front U-joint. If you're going with greasable units (and Jerry & I were debating that on another thread) then you might want to cut a little trap door on the passenger side of the tunnel that would give you easy access to it. Just unbolt the seat and open the trap door and you're right there. That's my next project. But as you're putting it all together, ask yourself "Am I going to be able to get to this U-joint once I'm done?"
