  #22 (permalink)
Old 07-17-2008, 06:45 AM
Barry_R Barry_R is offline
Easy to do on number one. The magnet or claw tool will get it done. Even easier if you pull the distributor because it will let you put some light down there and give you a place to slip in another tool/access hole if you need it to get the lifter out.
Look at the lifter pretty close once you have it out - - it can still have a break-in failure even after the pre-break in service. If it looks perfect externally - toss in a new one butterred up with the appropriate cam sauce and get her going.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
