Old 07-19-2008, 06:27 AM
COBRAMAN 484 COBRAMAN 484 is offline
I tried a 100amp powermaster but it wouldn't fit, it was about .125 inches to long. I picked up a 100 amp chrome motorola. It works fine the only problem I have is even with the smallist pully I could find, at night with the lights on when the engine is at idle (1000rpm) my wideband meter won't show the air fuel readings. It defaults to 14.7 when the voltage is below 12volts. I use a tempo regulator and have it set at 14.5 volts but i don't think I want to set it any higher.
