  #21 (permalink)
Old 07-21-2008, 02:10 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
The hydrogen and 02 mixture or browns gas I am using is in addition to the gas because of the byproduct of water. The engine mods mentioned earlier are to deal with the contamination, corrosion and rusting if used in higher amounts. The addition to gas is small enough not to be an issue. This is also very low pressure so again not a big deal and no storage issues. Gas can easily be extracted with 20 amps at 3 volts. Voltage is dropped to 3 to 4 volts to reduce amperage draw total and easier to work with too.
427 s/0 is talking about a whole different deal or amount of H20 because of pressure, storage and delivery issues.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
