Old 07-21-2008, 04:42 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by Russ Dickey View Post
here's my beef: why can't one of these magazines do a REAL comparison of an original vs. a replica, where the cars are prepared with the same engines, same transmissions, same gearing, same wheel/tire setup, etc?
You find one original Cobra owner like Jim who is willing to submit his car for the test. The original doesn't have to be 100% stock, but should probably be close. Then you approach each replica manufacturer and have them submit a car that is built to the same specs as that original. Same engine specs must be used, same transmission, same gearing, same wheel/tire combo (or at least same size, brand, and model of tire). Heck, you could even have one engine shop build the engines for all of the replicas, so that they are all as close as possible.
In fact, to avoid "ringers" that might be built and submitted by the replica companies themselves, you could have one independent shop build them all. That way, they could give detailed pros and cons of constructing each. Each one would be built as closely as possible to the original car used in the comparison, but could come with whatever "top of the line" suspension or brake options are offered by the kit manufacturer. And they would build it using just the regular assembly manual that comes with each kit, without any "creative engineering" tricks and tactics that might be used to give the car an unfair advantage.
And after the cars are all built, you do a Car & Driver style road test. The exact same drivers have to drive them all. Then and only then could we ever see a truly accurate comparison of real vs. replica.
Nice fantasy.
There has already been several "cobra comparison" tests, comparing different replica's. If they all have the same driveline, then I would think straight line performance will be very similar, the lighter car wins. With the same driver, driveline, I would think you're not only testing suspension/chassis design, but also chassis set-up.
From my memory, one magazine, maybe car and driver, did a comparison of several different cobra's, ERA (roy allen), Herb Adams VSE (matt adams), and I think a classic roadsters, and maybe Contemporary?
By participating in this, I would think the replica manufacturers have more to lose than gain. There will be one winner and 5 losers. I think each replica manufacturer fits a niche, and comparing their performance characteristics may not be beneficial to their sales, that is concerning the losers. I think it's best for individuals to decide for themselves which cobra may be the best for them based on price, convenience, design, i.e., weighing all the pro's and cons.
What I think would be a better comparison would be that of the engine builders, buying crate engines, and see how they really perform, or last, with a good running on the dyno. KeithCraft, Gessford, FE specialties, Southern Automotive, etc. However, I don;t think the engine builders would really want this comparison either.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
