Old 07-22-2008, 05:22 AM
Double Venom's Avatar
Double Venom Double Venom is offline
MT,
Being in business for over 30 years building custom cars I have had " three" normal garages and my last one (all due to growth) is a Kentucky Steel building. I will NEVER build another Brick/wood garage. My building is probably larger than what you ared planning, 40x42 with a 16' peek. (I also repair large boats)
Do not use or order the insulation that comes with the building-cheap stuff, but do as mentioned abover insulate as you build with an upgraded inisulation. In my peak I had a 4x6 steel beam welded in place which I use for anything from picking up boats, to engines of course, and Cobra bodys for on/off the frames. Fortunately I was able to put "In floor" heat in place and I am here to tell you it is simply amazing heat! Put in some other auxillary type heat, i.e. overhead forced air. I use the heater very sparingly but on those cold mornings where it is below 50' and later into the 70's a little immediate heat is nice. If it is just plane winter out I run the floor heat 24 hrs a day. Simply amazing.
My building is all steel, no wood, and it gives me a full 6"shelf all the way around the building every 2'. At first I was going to close in the walls but with the help from a special engineer who recommened a special (and very, very cheap professional insulation-silver) I wouldn't cover the walls for anything at this point! I love the build in shelves and anything I have to hang or put up that is heavy I simply use 1/2-to 3/4" plywood, it 2' or 4' wide and mount it then mount what ever I want to mount on the plywood.
My son and I put the entire building up and functional (with a little help in between) in two weeks straight work.
Personally I would not go with Kentucky steel again, good building but their support was really not there. Many buildings and ways to build on the market, but these things are awesome!
Qustions? Just ask.
DV
