Old 07-22-2008, 01:25 PM
strictlypersonl strictlypersonl is offline
Originally Posted by vettestr View Post
CobraV8, YES that is what I am saying, from the start I have identified the max amp draw to be around 20 amps!! 20 amps is less than your AC compressor clutch and blower motor consume in your daily driver but it gets cooler inside.
Bob, I bet you separated oxygen from water in a high school lab just like me and tons of other kids and that was with a battery, plates and a little wire. ...
Actually, I majored in Chemistry at RPI (getting A's) for 2 semesters before I switched to Physics.
There is only one way for this process to increase efficiency, and that is if it allows more timing advance by inhibiting detonation. Hydrogen has an octane rating of 130 but the volume you're introducing is so small that I doubt that it can have much effect. You would probably get a better result with pure water injection.
My original post's estimate of the poor efficiency of dissociating water stands. This a a sucker's bet.
