Old 10-05-2001, 12:45 PM
coyled coyled is offline
Mine came with 250 pound rear springs, 450 fronts, and no sway bars. We went to 600's on the back and an original style front bar. The car then handled great with just a little low speed push. It would still roll , then set, which in corners close together you would really feel the effects. I then called pro shocks and found out that I had street rod(soft) shocks. I sent the shocks in for a revalve and it is way better now. The other suggestion would be a brake balance bar to get some more rear brake in your hi-tech. Mine used to dive under brakeing but now I have the adjuster, so I have lots of rear brake in the car now. good luck. scott
