Build to last
I have the walls anchored to the slab and the rafters tied down with hurricane clips to the walls. When a tornado (the largest pest) passes by maybe all I will lose is the sheet metal roof. If it gets to close all I will have is a clean 8 acre lot. Plus with plywood inside and outside it is a lot cooler inside. I can hang anything anywhere inside the shop on the plywood walls. Low maintenance gives me more time to drive the Cobra.
I'm going to retire in 1 1/2 to 2 years. I build a place to play. I also have a shooting pit behind the shop.
Dwight
I have cleaned up the front and side of the shop since I took the pictures but the grass still needs cutting.
Reason: add note
