Thread: Side Pipes
Old 07-23-2008, 11:14 AM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Default SPF Sidepipes/Headers...
I've had #770 since October 2000...and NEVER had a header or flange bolt/nut come loose enough to lose one. But...I've had to tightened them up several times before I hit on a solution.
I ended up using all stainless bolts, nuts, and lock washers. Using a 3/8" drive ratchet with extensions and deepwall sockets, along with a box end wrench for the bolt head, installation, removal and maintenance is really easy...no problems at all reaching any of the six fasteners. All the taping, wrapping, and otherwise protecting the body and pipes is really overkill and typical of a new owner, but no problem...we all understand your concerns and precautions. But basically, you're taking waaay, waaaaaay more pains than you need to...the paint and ceramic coatings are much more durable than you may think. Trust me when I say you'll pick up waaaay more nicks and scratches in one week of driving than you'll ever incur while installing your side pipes...!!!
After installation and initial run in, while the headers, pipes, flanges and bolts are still good and hot...revisit each one and tighten them up again. You'll find that after heating them up, you'll be able to get as much as a full turn on each fastener...! The heat obviously makes them expand quite a bit...and this is what causes them to get loose. Tightening them up while hot insures they stay tight when they heat up again. I don't need to tell you to be careful while they're hot...or you'll burn the Bejeezus outta your hand, arm, and anythng else that comes in contact with the hot surfaces...ask me how I know this...!!!
Also, at least once a year, just after a hard drive, again while they're still hot...go 'round and tighten them all up again, or at least try to. The key is re-tightening them while they are extremely hot - just after a drive.
This procedure has worked well for me for the past 8 years...hope it helps you out.
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
