Old 10-05-2001, 04:46 PM
mkcobra mkcobra is offline
Default Minor adjustments and suspension adjustments
Hello Don
if you remember i recently bought Jim V. cobra here in Dallas. i was wanting to make some adjustments and i am not sure how if you can help me i would appreciate it. first. you mentioned that the rear springs are adjustable can you tell me how to adjust them and if there is a manual or documents i would love to see and have them. the front end is not to bad but it could be a little stiffer. this one had the MustangII front and the Ford 8.8 rear with adjust coils. also the drivers door rubs a tiny bit right at the front edge of the inside panel, hard to describe but basically it needs to come up on the hing an 1/8 inch or less. thirdly my fuel gauge light went out and it is tough to get behind it. do i have to take the whole dash off to replace the bulb. next how easy is it to change the seats they are nice but set to deep for me i am alittle shorter than jim. they move forward but they set back and down which is still akward. can you adjust the gas pedal further forward the clutch and brake are in good positon.
