Thread: Side Pipes
Old 07-24-2008, 08:09 AM
McD00's Avatar
McD00 McD00 is offline
Cobra Make, Engine: 931 mangled in parkinglot incident - traded for new house roof <sob>
Originally Posted by RonNichols View Post
I've had my side pipes off quite a few times over the past year. I used to use stainless fasteners until recently. It seems that I have run into shoddy fasteners that once torqued, would seize, and then I simply just unscrewed them into two broken pieces. The box had an origin sticker that said "made in China" so I just figured I would change. I have since replaced the fasteners with grade 8 bolts with a serated flanged nut seated onto washers on both sides of the flange. After several months of heat cycling, its still tight.
R
Ron,
As you have found out sometimes those high end bolts are not right for certain applications....just to brittle.
I find it interesting that your big bore pipes made less power than your smaller ones. So you are saying smaller is better?
Long live the Cobra!!
"...Just Shut the phuque up and Move on please..."
