Old 07-26-2008, 04:41 PM
Buzz's Avatar
Buzz Buzz is offline
Uniques (normally) have adjustable coilovers on all four corners, so tweaking your ride height is simply a matter of turning the adjusting collars on the shocks at each corner until the desired level is attained. Bear in mind that some settling wil occur after a couple of miles so it may take some trial and error to get it just right.
The center section of the jag rear is bolted to a plate on the underside of the rear frame. Moving it back would invlove a whole host of modifications including shock mounts, driveshaft, trailing arms (adjustable), brake lines, sway bar if equipped, and of course, the mounting plate holes. Then there may also be the issue of altering the manufacturer's geometry and frame loading specifications.
I have 275 60's (which are taller than the 295 50's) on mine and I had a rubbing issue crop up under hard cornering. I was reluctant to raise the ride height too much but luckily, I found that I had a broken right front sway bar mount. I fabbed up a new one and the problem went away. I would like to lower the rear a bit more now, and I am considering retrofitting a Unique rear sway bar to flatten out the cornering even more.
I hope this was helpful.
Tropical Buzz
