Old 10-06-2001, 08:32 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Mike, I was answering your questions in order so now I know who you are. The front and rear springs are adjustable. The rear springs are adjusted through a hole behind each seat in the corner of the package tray. It uses a 7/8 socket. The rod adjusts up and down. Up for less stiffness, down for more. This also changes the ride height of the car. The fronts are Carrera coil overs. They are adjustable but you will need a spanner wrench. They adjust at the bottom of the spring. You will need to take the weight off the front and turn the spanner nut up for increased stiffness. The fuel gauge light is at the top of the gauge and just pops out from it's socket. No need to remove the dash for this. Reach your hand up and pop the light out from the gauge. The bulb is in this socket. You may want to just reach and check the wires first to make sure one of the wires didn't come off. There are 2 wires going to the light. If I understand you correct the door is rubbing on the inside kick panel. Door adjustment is very tricky, If you want to try it you will need to remove the door panel and the kick panel. There are 3 bolts on the front of the door hinge behind the kick panel that allow the door to move front to back. There are 2 bolts at the front of the door which you can get to through the hole under the door panel. You can move the door in, out, up or down. This is tricky. You don't want to move much because a small move can change the door alot. The seats can be moved. There are 4 bolts under the seat through the frame that hold them in place. You could redrill to move the seat farther forward. If you just need to raise the seat you could add spacers at the rear bolts to bring the back up for a more vertical seat back. There isn't much you can do the bring the gas pedal forward. I think the seat is the way to adjust your reach.
Don
